200tdi into a 6 cyl 2a lwb
Posted: Wed Jun 30, 2021 9:39 am
by dickandjill
I am considering fitting a 200tdi into a 6 cyl 2a lwb
I am aware the gearbox is set further back and that the bell housing will need changing to a 4 cyl one also that 4 cylinder engine mounting brackets are needed to bolt on to the 200tdi
What chassis engine mounting brackets will I need to use ? Can the 6 cylinder ones be cut off and moved ?
I am also considering using an LT77 main gearbox and and Ashcroft adapter to mount it to the Series transfer box but will still need to move the chassis engine mounting brackets.
