I am considering fitting a 200tdi into a 6 cyl 2a lwb
I am aware the gearbox is set further back and that the bell housing will need changing to a 4 cyl one also that 4 cylinder engine mounting brackets are needed to bolt on to the 200tdi
What chassis engine mounting brackets will I need to use ? Can the 6 cylinder ones be cut off and moved ?
I am also considering using an LT77 main gearbox and and Ashcroft adapter to mount it to the Series transfer box but will still need to move the chassis engine mounting brackets.
dickandjill
Re: 200tdi into a 6 cyl 2a lwb
Helo. I am new to the forum. I am currently restoring a 1969 2a Dormobile. It originally had a 6 cylinder petrol but has been replaced with a diesel 4pot at some point.
I'm on the look out for an origional 6 cylinder to bring it back to its original glory.
Are you any closer to replacing your engine? I would be interested in giving you an offer if you do take the 6 cylinder out.
