Hi everyone
Hope you all had a good christmas.
Does anyone know the ULW of a five door dormobile ?
Thanks Kevin
Dormobile weight
Dormobile weight
1970 LWB Dormobile "Gertie"
1964 SWB
1964 SWB
Re: Dormobile weight
I had mine on the weighbridge at my local feed merchant and it was 2020 kilos. No baggage, just the carpets and furniture !
TDI though, I suspect a 6 pot would be a couple of kilos more
Thanks Alex
I was just checking the legal situation with regards to seat belts, the manual says that if the vehicle has a ULW greater than 2540kg and used before Oct 1981 then they are not required.
With the info you supplied this obviously is not the case
Seat belts required !
Thanks kevin
Thanks kevin
1964 SWB
1964 SWB
